Do I need a HDCP monitor to watch sky HD?
Caporegime
24 Dec 2005
Autonomy
Do I?
Looking for a monitor to watch some Sky HD via HDMI
22" does it need to be HDCP or if a monitor has HDMI input it already is HDCP compliant?
Thanks
Yes you need HDCP to use HDMI output from a SkyHD box. All HDMI inputs will be HDCP compliant, most modern monitors with DVI should also be HDCP compliant :). If your monitor has DVI check on the manufacturers website whether it is HDCP compliant.
Cheers Meatball
