- 18 Oct 2002
- Stone, Staffordshire
Current setup is:
Bedroom
O2 broadband (max connection is 2.6meg)
Using the supplied O2 router connected to a Dreambox DM500
Garage
Windows Home Server - HP ML-115 (Gigabit NIC)
Windows XP PC - (100Mbit NIC)
Gigabit Netgear 4 port switch
Lounge
Netgear WGPS606 Wireless Bridge wirelessly connected to the o2 router.
Hard wire connected to
1 port to the gigabit switch in the garage
1 Xbox 360
1 Tivo
Wireless Items
2 x Toshiba P300-156 laptops (802.11g) - Vista 32bit
1 x iphone 3G
1 x ipod touch
Wii
Problem
I get connections of 48 - 54mbit on the laptops and transfering files from the laptop to the windows home server is painful - 600 - 700 KB/Sec with Windows Task Manger showing network utilization not going above 15% so this is the prime purpose of the upgrade.
Questions:
If I replace the Netgear WGPS606 with D-Link DAP-1522 Xtreme N Duo Wireless Bridge/Access Point plus wireless n PCMCIA or wireless n USB adapters for the laptops will I see an improvements in file transfer speeds and if so what is realistically acheiveable?
Anything else I should look at changing at the same time? I don't see a point / need to upgrade the router as I am not going to be maxing out that connection.
Also will I get wireless N speeds on the laptop if some legacy devices like the wii and ipod/iphone only have g? Will it throttle my entire wireless network back?
Bedroom
Garage
Lounge
1 Xbox 360
1 Tivo
Wireless Items
1 x iphone 3G
1 x ipod touch
Wii
Problem
Questions:
