Problems when trying to share media with PS3!!!
4 Jun 2009
South Wales
hi, i cannot share my media with my PS3 in XP, i have tried to follow guides online, however i always face two problems.
1st Problem:
the process will not start and this error message keeps on re-occuring.
2nd Problem:
This image shows wmp11 freezing everytime i tick the box and select OK, i am beginning to think this is being caused by the 1st problem as the process to share the media is not starting.
When on the PS3 it says UPNP is enabled on my router which leads me to suspect that it is the computer, not the router or PS3.
any help would be great thanks :D
i have now managed to fix both those problems above, unfortunately i cannot see the ps3 in the image below, i have tried searching for the computer on the ps3 etc, yet still no luck
Google TVersity - very good media sharing application that works nicely with the PS3.
Alrighty then, found a solution for the problem.
Type Services.msc in Start, Run dialog
Locate and double-click the UPnP Host service from the list
Click the Log On tab
In the This account text box, type in NT AUTHORITY\LocalService
Set both the Password fields blank
Click Apply, OK
Restart Windows and set the UPnP Host service to Automatic or Manual, and then start the service.
Just incase future people have this problem.
Might be worth a shot.
