PS3 slim... BD remote... duh... wah?
1 Oct 2006
Over at a mate's trying to pair his BD remote to his PS3, and not having a huge amount of success. Have tried going in through the manage bluetooth devices and started to scan but it finds nothing.
This is what the destructions say to do, but it seems this isn't doing it - any ideas?
Cheers
Cheers
There's a specific option for pairing the BD remote.
Accessory Settings > Register BD Remote Control
You use a different part of the menu, can't remember what but it's fairly easy to find. It'll prompt you to hold the select and start buttons on your blutooth controller (if you can't see this message you're doing the wrong thing).
Cheers
Go to register BD remote in accessories above blue tooth devices ;)
Its a Panasonic TV though, I dont recall asking it to, I just leant on the remote and it moved stuff on screen!
Yeah my G10 controls the XMB, but no further than that. The telly will turn on my Samsung HT as well as the PS3 and control both fairly well. Isn't it part of the HDMI spec?
