- 28 Dec 2009
- Wales
Hi
I wonder if anyone can help me?
Just built my new rig as follows: AMD 965 Phenom 2, 4 gb g-skill ram, WD black edition HD, Asus 5770 GPU and a corsair 650 psu.
I clean installed winows 7 pro 64 bit.
However, I downloaded and installed the latest Catalyst suite and whilst it is showing in the start menu its not showing in the tray and if I click on the menu the blue circle timer briefly appears then nothing happens.
I have managed to uninstall evrything using drive sweeper and start fresh however the same problem reoccurs. And if it helps, when in the uninstall panel in windows it will not even let me uninstall, had to use ccleaner.
Hope someone can assist as its driving me spare!
Many Thanks
Andrew
Many Thanks
Andrew
