Colleagues,
We have received a significant amount of 5*** cards today. And All back orders for the display adapters will be shipping with one spare for sale.
*** *** Sapphire ATI Radeon HD 5970 OC 2048MB GDDR5 PCI-Express Graphics Card @ £539.99 inc VAT *** ***
The fastest graphics card on the planet, the ATI Radeon HD 5970 delivers an unrivaled HD gaming experience so you can play the latest, most demanding HD titles like never before. Engineered for speed, this next-generation powerhouse delivers unprecedented performance straight out of the box. Unlocked, this graphics card has massive headroom so you can take control and push your hardware to its full potential! Expand your visual real estate across up to three displays and get lost in the action with ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. Among the first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals with explosive performance so you can dominate your gaming competition.
- Core Clock: 735MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4040MHz (Effective)
- Memory Bandwidth: 256GB/s
- Processing Cores: 3200
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I & 1 Mini DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- Warranty: 2 Years
Only £539.99 inc VAT.
ORDER NOW
*** *** Sapphire ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card @ £234.99 inc VAT *** ***
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 725MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 128.0GB/s
- Processing Cores: 1440
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £234.99 inc VAT.
ORDER NOW
*** *** Sapphire ATI Radeon HD 5870 1024MB GDDR5 PCI-Express Graphics Card @ £347.99 inc VAT *** ***
- Core Clock: 850MHz
- Memory Clock: 4800MHz (Effective)
- Memory Bandwidth: 153.6GB/s
- Processing Cores: 1600
- HDCP Capable
- ATI Avivo HD
- Includes: Colin McRae DiRT 2 & Battlestations Pacific
- Warranty: 2 Years
Only £347.99 inc VAT.
ORDER NOW
*** *** Sapphire ATI Radeon HD 5750 Vapor-X 1024MB GDDR5 PCI-Express Graphics Card @ £127.99 inc VAT *** ***
Now, more people than ever can experience real innovation in DirectX 11 gaming with ATI Radeon HD 5700 Series graphics processors. Loaded with advanced technology, these GPUs have the power and premium features you need for fully immersive gameplay. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first GPUs in this class to offer full support for DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition. The Vapor-X cooler runs cooler and more quietly than other solutions, increasing reliability and allowing enthusiast users significantly greater headroom for performance tuning.
- Core Clock: 710MHz
- Memory Clock: 4640MHz (Effective)
- Processing Cores: 720
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £127.99 inc VAT.
ORDER NOW
*** *** Sapphire Active DisplayPort to Dual-Link DVI Adapter @ £79.99 inc VAT *** ***
In addition to spectacular image clarity, speed and visual effects, the Sapphire HD 5000 series supports the new multi-monitor mode known as ATI Eyefinity. This allows a single GPU to display a choice of images over an array of several monitors. The cards support up to three monitors, with a resolution of up to 7680x1600. This opens up exciting possibilities not just for multi-screen gaming, but also for information systems, multimedia systems and promotional displays.
However, with this family of cards, although two of the screens can be connected directly to the DVI or HDMI outputs on the card, the third display has to be driven from the DisplayPort output. Some users have expressed concern about the cost or availability of DisplayPort compatible monitors, or a wish to match existing monitor styles.
Sapphire has introduced an active powered DisplayPort to DVI converter, which allows any standard DVI monitor to be used as the third screen and enabled in Eyefinity mode. This allows users to update their existing multi-monitor setup to use Eyefinity, or to add a lower cost DVI monitor to complete their Eyefinity system. The SAPPHIRE converter is simply plugged into the DisplayPort output of the graphics card, together with a standard USB connection to provide power. A standard DVI monitor cable can then be connected to the female DVI connector on the unit.
Only £79.99 inc VAT.
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
ORDER NOW
