my phenom 965 c3 clocking
I'm running at 3.9GHZ, where i've done more than 10 loops.
I don't need your "expert advise"...
I just don't see the need to justify myself to you or anyone else. :rolleyes:
its not about justifying yourself. people are only trying to help mate.
if your o/s crashs and doesn't boot back up due to a unstable system or even a slightly unstable system, you'll be ****** off because you'll need to reinstall everything. or another thing is if your doing something important and if the system crashs.
if a game or app that u use doesn't crash the 1st, or 2nd time, doesn't mean it won't crash sometime in the future if the system is unstable or slightly unstable.
now i'm at 3.8ghz, 2.6ghz NB, 7-7-7-20 ram timings. prime95/ibt/linx stable
now trying for 7-7-7-20 1t ;)
I thought the C3 stepping was the answer to getting the illusive 4GHz which was a problem for the previous stepping. Isn't that the case? :/
4ghz can be done but it needs 1.5v+..
its better to have 3.8-3.9ghz with a high NB frequency, than a 4ghz core clock with a 2.2ghz nb
agreed. The high NB freq will speed up the machine more then a extra 100Mhz, let alone the increase in vcore for the extra mhz
Air struggles to breach 4ghz... the 955/965 like to be kept cool if you can keep them under 50c then you can get 4ghz+ primstable at reasonable voltage (1.45v).. if you are pushing 55c - 60c then you are going to need 1.5v+ although the CPU's should be fine up to 1.55v.. if you can keep the temperatures sub 40c then there are examples on XS of 965 running prime @ 4ghz at around 1.375v
common stable air clocks are 3.9 - 4ghz, water can reach 4.2ghz... vcore very much dependant on temperature
true
but that also depends what stock vid u get.
also said its better to have a 3.8-3.9ghz core clock with a high NB frequency, than a 4-4.2ghz core clock with a 2.2ghz nb
yup IMC clock makes a lot of difference to the performance if you can get 2.8ghz you certainly notice the difference over 2ghz stock
weird today prime95 found a error in 3 minutes with the same settings as above...
i know its not the cpu clock because the system didn't crash. its ether nb or ram. i've set the ram timing back to 7-7-7-20 2t and im running prime95 again. so far its fine.
Temperatures?
These Phenom II's throw a wobbly at certain temperatures.
my ram default settings are 1600 7-7-7-20 1.7v but with 1.7v i can't run them at 7-7-7-20 , so i was told 1.75v would be fine, is that right? 7-7-7-20 is stable with 1.75v
yeah cant't see any problem with that, quite nice timings and speed there for the ram tbh
thanks
yeah my ram are Patriot amd gamer 'PGS34G1600LLKA, i had to rma the first set because it wouldn't run at 1600. the replacement are better.
so far it's done 4hours on prime95 , blend
