Money is relatively easy to get though, no amount of it can buy taste though![]()
That is true, there is no denying however that some of those cars make me a little tingly down below.
Is this a Gumpert?
Originally thought it was the Mantide, but that was the next photo.
Thought I'd seen it on Autoblog.
edit: erm, hang onOriginally thought it was the Mantide, but that was the next photo.
edit 2: okay, I give upThought I'd seen it on Autoblog.
edit 3: Got it - it's the Danish Zenvo ST1![]()
engine V8
aspiration Turbocharged & Supercharged
displacement 7000 cc / 427.17 in³
bore 104.8 mm / 4.1 in
stroke 101.6 mm / 4 in
power 823.3 kw / 1104 bhp @ 6900 rpm
specific output 157.71 bhp per litre
bhp/weight 802.33 bhp per tonne
torque 1430 nm / 1054.7 ft lbs @ 4500 rpm
driven wheels RWD w/LSD, TC
front tires 255/35–19 Michelin
rear tires 335/30–20 Michelin
front brakes Ventilated Discs w/6-Piston Calipers
rear brakes Ventilated Discs w/6-Piston Calipers
front wheels F 48.3 x 24.1 cm / 19 x 9.5 in
rear wheels R 50.8 x 31.8 cm / 20 x 12.5 in
steering Speed Sensitive Power Steering
f suspension Double Wishbones w/3-Way Adj Öhlins Shock Absorbers
r suspension Double Wishbones w/3-Way Adj Öhlins Shock Absorbers
weight 1376 kg / 3034.08 lbs
wheelbase 3055 mm / 120.3 in
length 4665 mm / 183.7 in
width 2041 mm / 80.4 in
height 1198 mm / 47.2 in
transmission 6-Speed Manual
top speed 375 kph / 232.88 mph
0 - 60 mph 3 seconds
http://i692.photobucket.com/albums/vv288/thechicco/Dubai%20Motor%20Show/17474_395547455343_611855343_104619.jpg[/IM]
What car is that?[/QUOTE]
The same question was just answered about 3 posts up :p
I forgot to read the 2nd page so I replied after 40 posts, me = dumb***The same question was just answered about 3 posts up![]()
And remember I said that Carbon DB9 was my favourite of show? I lied! OOOmmmFFfff :
