Dubai Motor Show........*Warning Pic Heavy*
  • Thread starter Thread starter Guest
  • Start date Start date
Is this a Gumpert?
WANT!
I don't think it is, I might be wrong though. But I wondered what car it was. The badge almost looks lamborghini-ish.
Looks awesome!
edit: erm, hang on :o Originally thought it was the Mantide, but that was the next photo.
edit 2: okay, I give up :( Thought I'd seen it on Autoblog.
edit 3: Got it - it's the Danish Zenvo ST1 :D :)
Thanks!:cool:
That thing is awsome:D:D
engine V8
aspiration Turbocharged & Supercharged
displacement 7000 cc / 427.17 in³
bore 104.8 mm / 4.1 in
stroke 101.6 mm / 4 in
power 823.3 kw / 1104 bhp @ 6900 rpm
specific output 157.71 bhp per litre
bhp/weight 802.33 bhp per tonne
torque 1430 nm / 1054.7 ft lbs @ 4500 rpm
driven wheels RWD w/LSD, TC
front tires 255/35–19 Michelin
rear tires 335/30–20 Michelin
front brakes Ventilated Discs w/6-Piston Calipers
rear brakes Ventilated Discs w/6-Piston Calipers
front wheels F 48.3 x 24.1 cm / 19 x 9.5 in
rear wheels R 50.8 x 31.8 cm / 20 x 12.5 in
steering Speed Sensitive Power Steering
f suspension Double Wishbones w/3-Way Adj Öhlins Shock Absorbers
r suspension Double Wishbones w/3-Way Adj Öhlins Shock Absorbers
weight 1376 kg / 3034.08 lbs
wheelbase 3055 mm / 120.3 in
length 4665 mm / 183.7 in
width 2041 mm / 80.4 in
height 1198 mm / 47.2 in
transmission 6-Speed Manual
top speed 375 kph / 232.88 mph
0 - 60 mph 3 seconds
Fairly safe to see the areas of the world not so hard hit by the resession :)
Id like to think that mentioning things like "hybrid" or "fuel efficiency" or "emissions" would have got you thrown out of the show.
