Dont have any pics atm but will post as soon as the cam charges up.
The unit is not that bad after the first initial start up,It has to freeze 4l of water. after its don that its doesnt kick in very often. I just leave it on 24/7.
I just use a little res (lagged to hold the temp) then into the cooler useing both lines then into the CPU then back to the res. Spose you could go Res,cooler,CPU,cooler,res. think it will give you the same over all temps. You do need to run a strong antifreeze mix due to the chance of it freezing in the coil. O i have 2 pumps (fish tank pump in the res (750lph) and a OCZ pump in the case (res pump runs 24/7.sort of push pull thing). I wouldnt use a rad in this set up it will warm the water.but like the cold air thing nevver thought about that
There is a little of conden but i have just lagged the pipes.
Its a VERY easy way to cool the water loads better and easyer than a custom build (been there done that) and £400 less than Phase and can run 24/7
Edit: Forgot the fittings. They are just push on 3/8 but i step to 1/2inc after the cooler(only cos i had loads of pipe about the place) If you have a water cooler fitted atm you can fit this within 20mins. Hell you could fit it onto a H20
that would make - temps for £150. lol . Should buy a load and sell them with a fitting kit.
There is a little of conden but i have just lagged the pipes.Its a VERY easy way to cool the water loads better and easyer than a custom build (been there done that) and £400 less than Phase and can run 24/7
