networking linux to Win7
18 Oct 2002
Behind you... Naked!
Where do I start?
Ok, I want to get a Linux ( Ubuntu 9.10 ) PC to talk to a Win7/64 PC.
They seem to want me to enter domain info and Im not using a domain.
Tell me what I ned installed to make sure they talk.
I need more than this, but this is as basic as I can make my post.
SAMBA
Well in the past yes, I have used Samba, but I have not bothered with it for some time now and Its been a good year or two since I used it.
Seems silly to need it once again now?
But there you go.
I have not had the chance to go and test wesleys option of using the WG name as the domain, but I will grab an hour to play later on and install samba if need be.
SAMBA
But there you go.
On the Windows desktop you won't need to do anything, but on Ubuntu you may need to configure or install Samba (can't remember if the server is installed by default, but the client is)
If you're using samba you might want to install SWAT (Samba Web Admin Tool) as well - makes configuring the thing quite a lot easier.
There's a nice web interface instead of manually editing /etc/samba/smb.conf.
Code:
sudo apt-get install swat
Cheers for the info guys.
I know how to install and setup samba
I just have not needed to do it for so long now that I am wondering why I need to go back to it?
Ah well, needs must as they say.
I just finished work for the day, I have no call outs and I was hoping to grabn a bit of time, but as usual the wife has me stripping the daughters bedroom wallpaper first!!!
Wimmin!!!
