INTEL CORE i3 4.00GHz OVERCLOCKED BUNDLE - £349.99 inc VAT
9 Nov 2003
Leeds
For performance information please see the i3 Overclocking thred here: http://forums.overclockers.co.uk/showthread.php?t=18099548
This bundle pushes the performance of our 4.00GHz i7 bundle in games, at a fraction of the price.
*** *** *OVERCLOCKED* Intel Core i3 530 Clarkdale 4.00GHz / Gigabyte GA-H55M-UD2H Intel H55 Motherboard / Corsair 4GB DDR3 PC3-12800C9 1600MHz DDR3 Bundle @ £349.99 inc VAT *** ***
Representing the cream of the crop of today's bleeding edge performance hardware, OcUK's 'Extreme Bundles' are selected to satisfy the needs of the most demanding enthusiast.
OcUK Overclocked Bundles feature carefully selected components tested to assure compatability & stability, guaranteeing the integrity of the overclock.
We worry about the fiddling and tweaking, you just enjoy the performance.
This bundle ships pre-built and pre-overclocked direct from our Technical Department. All you need to do is attach the CPU cooler and power it up.
- Maximum Speed
- Maximum Stability
- Maximum Compatibility
- Maximum Overclocking
This Bundle contains the following components:
1 X Intel Core i3 530 2.93GHz Clarkdale overclocked to 4.00GHz!
1 X Gigabyte GA-H55M-UD2H Intel H55 (Socket 1156) DDR3 Motherboard
1 X Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9)
1 X Zalman CNPS10X Extreme CPU Cooler
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. During exceptionally busy periods this time can increase by 48 hours.
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced.
Note - The bundle operates above manufacturer specifications, as such it requires a quality power supply to operate with guaranteed stability. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range.
Note - Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Only £349.99 inc VAT.
ORDER NOW
I would have though they'd be able to each 4.2+ easily considering how well the 920 did and they are 32nm chips as well.
I was going to get one of the i5 750 overclocked bundles for flight sim x and dirt 2. Would this be better? It is still 4GHz but a lot cheaper bundle?
ringo if you are planning on using the built in GPU on the i3 I dont think it will handle games at all... You will need a dedicated graphics card
You will be able to get higher, but I don't think you'll be hitting 5Ghz with the i3s.
How come this isn't bundled with the H50 ? Would OC consider doing another package with the H50 in the bundle?
EDIT Or an upgrade drop down box +25.00 For H50 Heat Sink upgrade for example?
Are the integrated graphics disabled for this overclock, to improve the thermal conditions?
Great value though - makes £700 i7 bundles look a bit silly! :D
Somebody will try and pass on 6ghz...i just feel it. It bound to happen because nobody expects it.
Perhaps without that darned graphics chip...
Speaking of which, are there any graphics reviews of it?
doing a stability test with the H50 [8+hrs prime stable]
the temps are much higher as i am using the on chip vga rather than a third party card
will psit that up once its done a few more hours :)
