Wired 5Mb and Wireless 2Mb ??
18 Oct 2002
Nottingham
Hello,
I have just brought the Linksys Cisco WAG160n and its a lot better than the Belkin 54g i replaced it with.
With the belkin i could never break past 2Mb limit on downloads/speed tests. That was with a wired and wireless connection.
Now i have the Cisco WAG160n i have speed test download at 5Mb on a wired connection which is great. The router syncs at 5696kbps and IP Profile 5500kbps. Pings on speed test are 20ms on wired connection which is also great.
Now when i move over to wireless with the cisco all my speeds are haved ?? speed tests never above 2Mb, pings of 40ms :(
Why am i loosing so much speed when on wireless ?? its the small for every device that connects on wireless.
Why is there such a drop on wireless, i know wireless is slower compared to wired but not over 50% slower ??
When i run wireless tests the laptop is next to the router no objects in the way of the wireless signal.
The sercurity on the router is WPA2-PSK.
Any advice would be great.
Thanks Ben
(I am with ADSL24 ISP)
For starters, it's not a Cisco.
What other devices are you connecting to it at the same time? What speed does whatever OS the laptop's running say the wireless is connected at?
Just my laptop is connected at the moment via wireless no other devices. No devices on wired connection.
Stats from router if they help.
DSL Noise Margin: 15.3 dB 18.0 dB
DSL Attenuation: 28.0 dB 16.0 dB
DSL Transmit Power: 19.7 dBm 11.9 dBm
Downstream Rate: 5728 Kbps
Upstream Rate: 448 Kbps
Running Win 7 Pro 64 bit on laptop.
Windows states connection status speed ranging form 65.00mbps to 117.00mbps
Thanks Ben
The router stats are irrelevant, especially without the sync rate, but if it's >2Mbps with a cable then it doesn't make much odds what it's connected at.
If you have another device you can connect to it with a cable then try shifting something over the wireless network to and from that. It'll at least eliminate the internet connection.
Updated to show sync speeds,
Dont quite understand what your telling me to do with the last bit of the post.
Thanks Ben :)
If you have another machine, connect it to one of the router's switch ports and transfer something fairly big from one machine to the other.
It should go a hell of a lot faster than 2Mbps and if it doesn't, there's probably some issue with either the router's or your laptop's wireless cards.
Evening,
Well after using the Linksys WAG160N for a couple of days i have deciede its rubbish !
Unable to connect any windows vista computers. Flacky connection on machines that would connect and mainly rubbish wireless performace. For £90 it had to go back.
Got a refund and purchased a Belkin F5D9630UK4 G+MIMO Broadband Wireless ADSL Modem Router for £40.
It works great ! really easy to setup, all machines connect first time ! and the best bit 5Mb/s over wireless !!!
So problem fixed with a decent router :)
