Hello,
I have just brought the Linksys Cisco WAG160n and its a lot better than the Belkin 54g i replaced it with.
With the belkin i could never break past 2Mb limit on downloads/speed tests. That was with a wired and wireless connection.
Now i have the Cisco WAG160n i have speed test download at 5Mb on a wired connection which is great. The router syncs at 5696kbps and IP Profile 5500kbps. Pings on speed test are 20ms on wired connection which is also great.
Now when i move over to wireless with the cisco all my speeds are haved ?? speed tests never above 2Mb, pings of 40ms
Why am i loosing so much speed when on wireless ?? its the small for every device that connects on wireless.
Why is there such a drop on wireless, i know wireless is slower compared to wired but not over 50% slower ??
When i run wireless tests the laptop is next to the router no objects in the way of the wireless signal.
The sercurity on the router is WPA2-PSK.
Any advice would be great.
Thanks Ben
(I am with ADSL24 ISP)
Thanks Ben
