I like to use 3 partitions 1) OS/Apps 2) Data 3)Temp data. By keeping the temporary data in it's own partition it should help reduce disk fragmentation and keep things zipping along. Also I like to keep the swap file to a static size one the OS is installed to reduce fragmentation on it.
Temp files hardly contribute to fragmentation?! Have you ever seen the number of files created by FF/IE etc. when surfing!
Two advantages,
1) Hard drives are fastest at the outer edge which is where partitions are created from so you can use the fastest part for your OS say.
2) You can easily wipe just the one partition clean for any reinstalls etc. Useful for backing up by partition also.
I do, not sure you understand though. System has worked for me for many years, not forcing anyone to use it though.
i thought they was faster on the inner edge?.
Fragmentation is when a file isn't contiguous and is only a performance issue if sections are far apart. Some temp files, even several GB of them, would not cause enough fragmentation to have any performance impact. Particularly on an OS partition where you're not likely to be doing much writing other than temp files so there's nothing for them to get in the way of.
Whereas with your setup you have reduced performance by default because your temp files are right at the end of the disk so the heads have to travel a lot more.
I know exactly what fragmentation is, I even understand the MFT disk structure (It's hardly rocket science). You can say what you want and providing you never install another application on the OS disk then your fine.
If I could I'd use a small SSD drive (maybe 8/16gb) to use 100% as a temp drive.
But you believe whatever you want tis fine with me, but I believe I am allowed an IMO after 20+ years of working with PC's.
Unless you're installing and removing enormous applications all the time and never defrag at all there's no issue at all.
There's a 60MB/s speed difference between the inner and outer parts on the latest disks. That plus forcing the heads to travel so much makes for a daft thing to do and it does have a performance impact.
"20+ years of working with PC's" please.Post facts and information if you're trying to argue something not meaningless stuff.
