This line....How do you stop that dark theme resizing pictures on the forum?
This line....
img, img:link {max-width:1280px!important}
Thanks. I've set it to 1920, no problem with doing that is there?
snip
New install of Win7 deserves a new desktop
Rocketdock on the bottom with these Icons here
Rainmeter with 10ft HUD theme
CD Display with the default skin
Firefox with Stratabuddy, Omnibar, Personal Menu and Hide Menubar extensions and Strata40 theme
I can't remember where I got the wallpaper from, i've had it for ages!
could someone explain how to get the icons to work please?
Assuming you mean a dock, download some icons from say deviantart such as these unzip the file - copy/cut the folder - program files - rocketdock - icons - paste.
Then if using rocketdock just a simple case of right clicking on the icon you want to change - icons setting - icon:, click the '...' box and find and select the icon you want, click ok and it will be changed.
objectdock will be a similar sort of thing if your using that instead.![]()
works fine, thanks!
