G25 - Clutch & H Shift
7 Jan 2003
Gold Coast, Australia
I've been getting used to using my G25 with
Dirt 2 & Need For Speed: Shift
Now i want to take it to the next level and start using the Clutch and H Shifter; is this possible as i cant see the option to do so?
i wouldnt bother demon
i recon it will be ultra solid
ive thought about doing it but im not going to
I have a G25, don't use the clutch & shifter at all in those games though. I do use it for TDU, it works quite well.
If you have Need for Speed Shift feel free to drop in to the Time Trial championships we are a friendly bunch and its lots of fun, it really pushes you to get better and get the most out of your game (and your G25) too.
I use the system you describe all the time -- it is awesome.
Right -- NFS Shift: Firstly you need to turn 'auto-clutch' off. And of course 'auto-gears' off.
Then just start using the H-box shift and ignore the 'sequential shift' buttons altogether. job done.
If your H-Box is only moving up and down between 3rd and 4th and doesn't stick in gear and doesnt easily go into '1st' or '2nd' etc .. it's in touring car mode -- -- mess with it (press it down) whilst trying the rotate the switch thing on the H box and you'll soon turn it into 6-speed mode.
It is AWESOME and MUCH BETTER playing the game this way. Just 2 final hints
1) Some cars on NFS shift only have 4 gears. If you drive 1 of these -- and try to shift into 5th -- the game will shove the car into neutral until you go back into 4th. The game isn't broke -- you don't have 5th for this car!
2) Press the clutch down for at least .5 seconds before changing gear -- give it another .5 seconds and release clutch. Otherwise you'll crunch the gears!
3) If you change into 2nd at 180 mph for 'fast breaking' .. this game will lock up all your wheels and you'll smash into a wall!
BOTTOM LINE: You do not have an option to turn on/off the H-shifter on ANY game .. you just always have 2 ways of changing gears -- the sequential shift or the H box.
i use the paddle shifters for dirt2,real sims i use the gearbox as it should be with clutch ect and for f1 its paddle shifter and auto clutch,tbh i anit touched dirt2 since i went into real sims like rfactor and alike.
When I had a G25 I found it was great for sims like GTR evo, but for the arcadey style games like DIRT2 and GRID it just didn't feel right and not much more fun than using a pad.
I'm not saying I didn't enjoy it with the wheel, I do think it was better, but the feedback and whole experience was much better imo in GTR evo. Maybe it was just down to how I configured it for different games, hard to explain but I just found some games MUCH more fun with it and some just a bit more fun and felt some felt a bit odd with the feedback.
Off topic a little here sorry, Me and my brother share a g25 wheel, in game e.g GTR evo we can change gear with the H-shifter without pressing down the clutch even though its set to manuel gears with automatic clutch switched off, any idea why this is?
Regarding the change of gears how do i configure the H shift under the options becuase it only say change up and change down not specific gears?
With the clutch does it work more as a button than real clutch? I mean can you just push your foot down and let go? Will the car jerk or anything? Also do i have to configure the clutch as a 'clutch' as i can see an option to edit the control settings for it.
On need for speed shift --
Look below where it says up and down using the scroll bar on the right hand side -- there you go -- each individual gear!
The car won't jerk (and bog down) from lifting the clutch too fast that I notice -- however normally at this time my accelerator is to the floor anyway ..
Awesome thanks mate! Lol so short sighted!
If the clutch isnt used when set to manually does it drastically affect the performance of the gear change?
