Sorry for starting another thread about unlocking, bit late to the party
I'm getting inconsistent results when attempting to unlock additional cores my PII 550BE and I hope you guys can offer some advice as I don't know much about changing bios settings or overclocking beyond what I've read on these boards
I'm using a Gigabyte GA-MX790X-UD3P with F5 Bios. EC is set to Hybrid and ACC is auto on all 4 cores. Everything else is set at stock settings, no overclock (yet) and I'm using a stock cooler.
Comp will post successfully and lists the cpu as Phenom II X4 B50 and Windows 7 64bit loads normally.
The weird part is that windows installed drivers for the extra cpu's and they show up in device manager, however CPU-Z and Prime95 only see 2 cores and msconfig only allows 2 cores as well.
I've tried setting ACC to 0% on individual cores but no luck getting CPU-Z to see more than 2.
Any ideas on how to get the 2 other cores recognised? I'd like to run stability tests to know if they can be used or whether I'm best turning my attention to overclocking the 2 cores I've got.
.I'm getting inconsistent results when attempting to unlock additional cores my PII 550BE and I hope you guys can offer some advice as I don't know much about changing bios settings or overclocking beyond what I've read on these boards
Colour me happy, it works!
How did the temps look?
