Should I upgrade to Windows 7
6 May 2009
Going from 2gb 939 system soon to 775 and 4gb. Would games and programs run better in Windows 7 or XP?
Primary needs are internet and old version of winamp
I can't think of any notable benefits that XP has over W7.
It's crazy to go to the former instead of the latter.
Windows 7 by far.
Recently upgraded to W7 from XP myself and haven't thought twice about the change.
Just this week you made a thread saying you had already installed it. Also I've said before, just use the latest Winamp lite with classic skin.
Quite the detective. However you failed to spot that i said it was on a work computer that came with Windows 7 installed. I have tried the latest Winamp lite but always seem to go back to 2.5e and its better.
Suppose I can install it on a new drive and if i dont get along with it or it doent work properly can stick XP disk in and reformat
Also, on my work machine IE and Windows 7 doesnt like ebay for some reason. I start searching and it says not responding and have to close it. It works in IE (no addons) mode
I never use IE, I use Firefox instead, better at multiple tabs, and customisable, without adblock plus, the internet is horrible
