Im happy with my 550 quad, but id like one of these when they hit the uk
CPU part number HDZ555WFK2DGM
Box part number HDZ555WFGMBOX
I'm not particularly excited about the Phenom II X2 555 BE, but AMD has sweetened the deal a bit. This chip now supports hardware C1E, like the first Athlon IIs. And no, I haven't encountered any CnQ bugs with it.
The hardware C1E means lower idle power consumption (I explained it in greater detail here) and it's courtesy of the new C3 Phenom II stepping. A side effect of this newer silicon rev is that it should overclock better. Our old Phenom II X2 550 BE hit 3.5 - 3.6GHz on air at stock voltage, and our new chip did 3.8GHz in the same conditions:
Part of the success of our chip here is due to its nearly 1.4V default voltage. Lower default voltages may only see 3.6GHz without going any further. Pushing beyond 3.8GHz proved to be very difficult on air, at least with any amount of stability under Windows 7 64-bit.
