No-one really seems to care about matching tyres here?
[TW]Fox;15819551 said:
Fifth Gear did one years back - a Renault Clio on premium, budget and mismatched tyres. The difference was quite remarkable.
Interesting by mismatched do you mean mixing premium and budget together or say mixing 4 premium or 4 budget tyres.
Could we keep this on track, rather than taking a pop at someone because you dont like his car.
If you dont think a cheap hatchback needs good quality or matched tyres, perhaps you could explain why?
Hey i dont mind his car (just not enough power for my liking in a big heavy shell), i drive and E39 M5 :D
And tbh ive had my fair share of cars, both performance and runabouts and i never could tell the difference on the cheaper cars as i never drove them hard.
Hey i dont mind his car, i drive and E39 M5 :D
Cool, you should post it in the show your motors thread, lots of people here love those things.
Anyway, the main reason I see is stopping - an M5 is going to have the same inertia as a 520i (give or take) so will need the same amount of grip to stop it effectively. Other things like aquaplaning and comfort factors like road noise all make a different, good tyres aren't only beneficial on high performance cars, or even cars being driven to the limit.
M5 brakes are much bigger for starters and the tires are also wider (Rear 275-40-18's & Front 245-45-18) thus giving a lot me more stopping power.
I dont think i could tell any difference in road noise between my last set of tyres to the Continental Sport Contact 2's i run now as the cabin on the M5 is very well soundproofed.
Ok the technicalities are fairly irrelevant - but cheapo tyres WILL significantly increase stopping distance, regardless of the car
Had it around 7-8 months :D will try and dig some out for you's.
Really?
http://forums.overclockers.co.uk/showthread.php?p=15641507#post15641507
2nd Jan 2010, 15:12
what about a e39 m5 ? they can be picked up for between £10 - £13k has 4 doors and very quick.
They are nice cars but I'm sure that the running costs far exceed anything I could afford.
they get about 30miles to £10 fuel around town and 50miles on a run.
i would love one :D
I wouldnt say significantly otherwise they wouldn't be allowed to go on cars as they would be as bad as bald tires.
I would say the softer and harder compounds would contribute more towards stopping distances.
Unfortunately the UK legislation on tyres is pretty laughable, but there's a lot of data that shows budget tyres do cause a big increase in stopping distance
I like to make my own tyres out of old shoe soles. I feel it makes my driving experience more interesting.
But in all seriousness, I find I replace an axel at a time. I find that my fronts out wear the rears by a fair bit, I think this is fairly normal?
In an FWD car, of course - the fronts are steering and driving, the backs are doing sod all
