Its actually pretty low, the front intakes are 140mm, at 1000 rpm, rear exhausts are 120mm at 1500 rpm. Definitely worth the price, i moved from an akasa eclipse which was a fanastic case. The a70fb is in a different league altogether.
If i was to get one i would be fitting a tall cpu cooler. Seems like there is plenty of space yeah? Really tempted now. Was going to get a new case, CPU cooler and tv card but might scrap the tv card for now and got for this case.
Don't think you'll get much taller than my Tuniq Tower 120, and there is still space to spare.
Using a thermalright ultra in mine and it fits grand. The ultra is 160.5mm high.
Very tempted by it now. My current card is not the longest but i plan on getting either one of the 57xx or 58xx cards soon.
Hope you dont mind all these questions. Just dont want to change my mind again in a few months.
The top fan joins the daisy-chain after running down the back of the motherboard tray. They are then easily attached with one molex
Yep, all three fans come with a passthrough 4-pin molex connector, so each fan is plugged together and then plugged into one 4-pin molex from the PSU.
BUY IT! BUY IT!![]()
PSU is screwed to adapter piece which can be turned.can you turn the psu upside down so the fan is on the top?![]()
