TaKeN, I'll try my best to explain, it seems long winded but isnt.
This is assuming your on window 7(shouldnt be much different for othere OS's)
(*) denotes, (these could allready be gone after unistall)
Fisrt unistall all ati through control panel as normal and reboot.
step 1, open a folder, hit organize, hit folder and search options, click view at the top, under Hidden files and folders, select the bottom one, show hidden files, folders, and drives, apply it, ok it, and close off your folders.
step 2, Go to, my computer,local disk (C), delete the ATI folder if theres one at top(*).
go to program files ,delete the two ati folders(*)
go back, then go to program files (86x) delete the ati technologies folder(*) go to common files and also check for more ati folders and delete them(*)
then go back twice so your back at local disc (C), go into the new folder, ProgramData and delete the ATI folder(*),
then go back once so your back in (C) drive, go into users folder and in here should be a folder with your name on it with a little padlock (you might have to give yourself permission) go in there then into AppData then local, then delete the ati folder, then go back and go into Roaming folder and delete ATI folder
phwew, i think thats it
Anyone else get this MOM.implementation failed to load error?
because everyone assumes they know about the problem and don't report it?Why does ATi break stuff and never fix it? AF does not work in TDU anymore, and it's certainly a driver problem since older 9.8 drivers, maybe even the 9.9 drivers work fine with AF...
