ASUS the tight *******DS!
An update for you:
Dear,
This issue has been fixed in Oct, 2009. Now all P6TD Deluxe shipped with correct SATA cables.
Also.. just noticed that my P6tD-Deluxe says 'Cool Stack 2' on the bottom of the PCB when its advertised as 'Cool Stack 3+' ill assume a printing error on pcb 'its rev 1.0.0G' as the VRMs seem to have the additional copper insulation but with these two things now its making me nervious of Asus none the less.
Im at the point where I have just fitted it to the case (will finish build tomorrow) I cant be arsed sending it back for just cables and a PCB misprint. Hope I dont get any more issues.
Question Guys: Im using the Corsair H50 cooler, did any of you use the optional mini VRM cooler to aid air flow, that came with the P6TD-Deluxe?
I've recieved all my parts today and looked in the P6TD motherboard box and it only came with 2 SATA cables :rolleyes: and they are not long enough to reach my HDD and DVD RW.
I spent the best of £210 for this board and they skimp on the SATA cables. :mad:
FUMING!
I've had to order longer cables.
PWNED!
Dont worry i think your awesome and i love your advice on everything, i take this advice, not to buy off asus because there cheap scammers
PWNED!
PWNED? How old are you?..........GROW UP.
Also it's not "there cheap scammers" it's "they're cheap scammers"
Next time try and give some practical advice, or some sort of intelligent answer to people's questions.
Check out some of his other replies, really helpful,
http://forums.overclockers.co.uk/showthread.php?t=18111451&highlight=username_woolerland
Post 24.
I didn't use mine as I have no room for it to fit because of the sound card blocking it, but if you have adequate cooling in your case you won't need it.
No harm fitting it if you have the room though, good luck with the build.
