Call in an Airstrike bam done.
Squad match is just the normal game, but you and your friends are in your own squad so you appear in a different colour and can spawn on/support each other.
Be nice if it was that easy, getting to the point where theres a handfull of people attacking the objective and the rest of the noobs sit on that hill.
But of course when the apache is available they make a beeline right for it, only to run it into a wall approximately .0005 of a second after it left theground.
[TW]Taggart;15846571 said:I may have worked out a little hack to edit the faves tab.
Go to USER/my docs/BFBC2beta In there there is a file called gamesettings
down the bottom under saved passwords is the following
FavoriteGamesConnectDate=empty
FavoriteGames=
Mine is
FavoriteGamesConnectDate=148731206400;148731206400 ;148731206400;
FavoriteGames=Multiplay.co.uk :: Bad Company 2! #32;Multiplay.co.uk :: Bad Company 2! #03;[FR]Eliott Ness #11;
add that and it should allow u to see the servers in the favs tab. all we need to do is add all the multiplay server names to that list. heypresto!
EDIT YES IT WORKS, added Multiplay.co.uk :: Bad Company 2! #04 and it came up on my faves list.
edit2: edited this into my Gamesettings file and it works. Multiplay are upto server 60 as far as im aware. DW server will be up soon(tm)
FavoriteGames=Multiplay.co.uk :: DW Server;Multiplay.co.uk :: Bad Company 2! #01;Multiplay.co.uk :: Bad Company 2! #02;Multiplay.co.uk :: Bad Company 2! #03;;Multiplay.co.uk :: Bad Company 2! #04;Multiplay.co.uk :: Bad Company 2! #05;Multiplay.co.uk :: Bad Company 2! #06;Multiplay.co.uk :: Bad Company 2! #07;Multiplay.co.uk :: Bad Company 2! #08;Multiplay.co.uk :: Bad Company 2! #09;Multiplay.co.uk :: Bad Company 2! #10;Multiplay.co.uk :: Bad Company 2! #11;;Multiplay.co.uk :: Bad Company 2! #12;Multiplay.co.uk :: Bad Company 2! #13;Multiplay.co.uk :: Bad Company 2! #14;Multiplay.co.uk :: Bad Company 2! #15;Multiplay.co.uk :: Bad Company 2! #16;
Only thing I'm not using is that HBAO option. It seems to impact FPS too much atm but will no doubt be sorted soon.
THIS GAME IS THE BALLS![]()
I have no ******* idea how to play this game, but seems okay. Basic weapons are terrible though. £35? Meh. Should've paid the £25.
cancel it as im sure you could as your only on BETA, and pre order the high street version for £25 for the LE
