Hey, my Mac randomly turned off earlier and is now completely dead.
Anyway to try to test the PSU without the Mac to try to isolate the fault to the PSU or Mac?
Cant give you any advise except be careful, there are likely big capacitors in a psu that hold charge for quite a while![]()
Theres an apple repair place in Chesterton staffordshire called SL electrotech, give them a bell matey they are not to far away.
.Tried another PSU, the motherboard is dead. Any ideas how much a replacement will cost for a Dec 2007 model?
Feel a bit ripped off now, only got it Xmas 2007. Only lasted just over 2 years!
Well motherboards do fail... You didn't get the extended Applecare on it?
I would check that as the HE discount used to include the 3years coverage for free. It doesn't show up on the warranty checker too often though.
