If you read what he says properly :
" My H50 keeps my 920 sat at 27-31 idle and tops out at 58 @ 4ghz under prime "
Where does it say stock.... ?????
If that is what you were talking about then why would you say this:
Im sorry but i dont believe them temps, even the best custom watercooling kits cant manage those temps.
6c difference on full load with hyperthreading.... not a chance.![]()
Overclocked: 27-31 idle to 58 load is a 31-27 degree difference.
Stock: 24-29 idle to 35 load is a 6 degree difference, like you said in your post.
Which is where the dispute came about. You were talking about the temps at stock.
I think you should try reading things 'properly'.
