Ahh, the pave low bug is bloody annoying. Just got 30-0 on FFA and yet my killstreak is still 22. Stupid game.![]()
The bug doesn't work if you dont die. Therefore you should be 30-0, if you did it.
anyone on tonight? even tho this game is so annoying,i still have to play it
you know it![]()
cool you can have a shot at outscoring the beast :/
Hmm, definitely didn't die. I did however, get one pave low from a care package I stole, so maybe that's the problem? :/
I have Predator, harrier then pav but I still havent got any higher than a 17 kill streak.
similar to me; i have predator, attack copter, pavelow and have managed a 16 killstreak but no better.
You guys that play online, do you all know each other or can anyone join in?
what sort of level/skill are you?
You probably both managed better than 16/17 with that set up. If you have died the pavelow won't register it's kills. I have the same until I went 30-0 on ffa then the pave kills counted.
See if they'd run a Beta some of these bugs might have got squashed by release, but in their infinite wisdom they didn't
Unless this a paid beta test that I haven't been informed about?
It will still have the same crappy hit detection and lag when we all start playing online.
Whens the beta anyway or are they going to make the mistake of just pumping this out?
Thats a shame, no doubt the first couple of months will be riddled with glitches and bugs then. Even after the betas neither of the COD games where that great out of the box.
