- 29 May 2005
If a granny smith was an orange - what sort of orange would it be?
a prune?
isnt he xbox a tri cpu also?
A crap one![]()
Well it doesn't take much power to run games at 1280x720, med-high settings with no AA so a fairly basic, modern PC would handle it fine.
Something along the lines of a Celeron e3200 (yeah, they're pretty good now) or an Athlon x2 with a 5750/GTS250 would be quite a bit quicker for about £300.
The xbox 360 has the advantage that its games are coded with its exact spec in mind. This is why the games look better than if you had an old PC playing games that were (probably) designed for newer tech.
Except they don't. The graphics on consoles look ****.
That's a bit of a sweeping statement don't you think? Resolution doesn't always = image quality or the quality of the experience.
I'm not talking about just the res, but also the poor texture quality, draw distance, lack of aa, and sometimes, very poor framerate ( gta iv).
I believe this thread has been done ten kajillion times.
