Not sure what the noise is, but it sounds quite meaty for a 4 pot I must say.
Oil seems to be OK, it was topped up by the dealer when they took a look in November using the spare topup cannister they gave at the last service with just a bit left in there so I put that in today even though that won't make much difference![]()
Plus I'd have thought the oil low indicator (yellow) would have come on too or red if it were critically low?
[TW]Fox;15907678 said:Surely you checked the level first, right? What was the level at before you added more, and where did this take it to?
Not if its broken, which most are by the time they reach 6-7 years old.
You can see the top of it - the red thing on the right of the engine block.Does mrk's car actually have a dipstick?
I edited the post as it was OT, but cheers.It doesn't really get dirty even in these conditions , I just wipe off dust layers every few months and give the plastic coverings a coat of Chemical Guys trim gel to keep it looking "black".
