For a limited time only get the Belkin HD Gigabit Powerline Adapter for just £67.99 inc VAT - CHEAPEST IN THE UK!
Belkin F5D4076UK Gigabit Powerline HD Starter Kit @ £67.99 inc VAT
Create a multi-user HD home entertainment network through your electrical wiring. Imagine streaming flicker free HD movies, lag free gaming and more all at the same time. No need for special wiring, with Belkin’s Gigabit Powerline HD Networking Adapters, it is that simple.
Powered by Gigle Semiconductor’s mediaxtream™ chip, Belkin’s Gigabit Powerline provides a secure, stable networking signal anywhere in the home—even for areas that are hard to reach by wireless connections.
Because of its high Gigabit speeds and consistent connection, Gigabit Powerline reduces online gaming latency and provides large bandwidth, making it ideal for online PC gaming and ultrafast high-quality transmission of multiple video streams delivering content at 1000Mbps of speed.
Create an even stronger network by adding a third or more Belkin Gigabit Powerline HD adapters to your set up. This enables the Xtendnet feature that provides more stability and better performance, essentially making the network “self-healing.” The more adapters in your network, the more reliable the connection will get.
Setup of a powerline network is simple with its plug-and-play connectivity:
Plug one end of the Adapter into an available wall socket. Connect the other end to any device with an available Ethernet port (RJ45), such as a gaming console, set-top box, or computer
- Compliant Standard IEEE 802.3/802.3u. HomePlug® AV-certified. Coexistence with HomePlug 1.0
- Encryption Types Supported 128 Bit AES - Push Button technology to set up a random key
- Hardware Interface Type RJ45 10/100/1000 Mbps Ethernet, Mains power
- Humidity Operating: 10 ~ 85%, Storing: 5 ~ 90% non-condensing
- LEDs Power/Security; Ethernet Link; Powerline Link
- Link Rate 1000Mbps
- Max. Operating Range Up to 300m in wall powerlines.
- Max. Supported Clients 8 bridged devices per station.
Package Includes
- 2 Powerline adapters
- 2 RJ45 Cables
- Quick Install Guide
Only £67.99 inc VAT.
ORDER NOW
Package Includes
- 2 RJ45 Cables
ORDER NOW
