Nice to see they've finally fixed (or attempted to fix) this issue.
What's disgraceful is that the timing of this means it's almost certainly a response to the criticism of their drivers in a recent Tom's Hardware article and that it took this to actually make them do something about it.
but that could be down to not having enough voltage for your overclock. 1.175v is low for 1ghzJust started clocking my 5850, got a GSOD after a few mins in furmark @ 1000/1200 with 1175mV.
Loads of problems with these cards (thankfully i dont get any)
It's probably because you don't overclock ... just a thought.
This "fix" doesn't do anything.
I get it at stock speeds though?
I don't get it and I've had 3 5*** cards in my system now. My theory is that these cards are sensitive to fluctuations of the PCI-E bus speeds, and that MB's start to drift out of spec on the PCI-E bus the more the FSB is pushed. 100mhz becomes 103 or 97mhz or fluctuates between high and low values on the PCI-E bus.
I got grey screens with stripes when testing stability @ 4.2 ghz with a 20 multi on my i7. I dropped it back to 4.0ghz with a 21 multi and its been solid as a rock ever since.
Please contribute if you can.
http://forums.overclockers.co.uk/showthread.php?p=15924327#post15924327
It was, without question, the overclock on my CPU/mobo that was causing these issues and a few others have also confirmed this to be the case.
Your theory on PCI-E bus speeds is a very good one. What would you say is more likely to cause the problem, the speed fluctuating to a lower value (like 97mhz) or a higher one? I would have thought the lower one as I've never seen a motherboard with an option for anything under 100mhz.
Yeah but your system is overclocked even if your gpu isn't. I can get it 3 times a day if I try and run my system at 4.6Ghz which ran fine with my gtx260.
At 4.25Ghz I haven't had it for a couple of months.
