Cheers Fortune,
Order just placed, will give them a trial this weekend.
Thanks
Taff
No Problem let us no how they are for you
Cheers Fortune,
Thanks
Taff
Hmm... would be interested in the response time when someone gets these.
Supertaff or anyone else perhaps if you get this before installing to router could you do a ping test before and after to see what the difference is?
Thanks.
What I'll do is a comparison
Server -> Router -> HTPC
Server -> Router -> Netgear 200 Home Plugs -> HTPC
Server -> Router -> Belkin HD Gigabits Plugs -> HTPC
I'll do a ping test and also a file copy test.
If anyone wants any other combinations, as longs as they're not to complicated let me know and I'll give it a try.
Taff
Anyone thinking about it, do it. Powerline networks are great. Ok you don't get max speed. But you'll get more than enough. I got a set rated at 200mbps and it connects at 100mb.
Once you've used them you will never go back to cable or wifi.
How long are these on offer for? The only reason I ask is that I've just ordered a new router off ocuk, and may possibly invest in some of these depending on how good/bad the router wireless is!
Sounds interesting keep us informed I would like to see the results, can you also inclued which internet provider / router / and setup combination you have.
Ma ny apologies to those who have been waiting for my results on this.
I've been delayed as I've been putting my new study together so all my kit has been disassembled.
I finished putting my new PC's together last night. So I'm hopeful that I can set up a test either tonight or tomorrow.
taff
Test 1) Ping test run 4 times
NetGear HDX101 - Ping average 4ms (max 14ms)
Belkin HD - Ping Average 1ms (max 4ms)
Test 2) File copy - Copy file from HD of Gaming PC to HD of HTPC
NetGear HDX101 - Average copy speed 8.7mb/s
Belkin HD - Average copy speed 7.5mb/s
I am sure overclockers watch what I buy from other suppliers and then drop the prices to torture me. I kicked myself when I noticed Ocuk were selling them for £86 and I paid £100 about 2 weeks ago at this price its a steal.
One bit of warning about these, they are large and if your plug socket is near the skirting board they can have issues plugging in.
I am tempted to buy another pair so I have greater connectivity around the house at this price.
but overall this is a fantastic buy!How hot do these run?
The HDX101s I've had ran scarily hot. In fact, I managed to kill two of them, quite possibly due to heat issues. While that experience did leave a rather bitter taste, I got a second pair but bodged a Cat 5 run in while I was waiting. That bodge is still there and the HDX101s never got taken out of their box.
If these are substantially better quality, and in particular run cooler, then I'd consider replacing the Cat 5 with these and selling the HDX101s.
so overall you do gain advantage when using this powerline compaired to standard ones... It's making me consider buying one![]()
