 - 26 Jan 2009
 - Swindon, Wilts
@NvidiaDan
I would suggest you could try and fit that 24pin under the gap on the left side of your graphics card nearest the expansion slot cover. Its hard to make sence of it in words but youl get the idea from my build log. I did it with my 8pin cpu power connection and had loads of room left over. It was the only solution i could think of.
Link to build log:
http://forums.overclockers.co.uk/showthread.php?t=18057487
Its the 6th picture down should see the cable going under.
Link to build log:
