Best Windows 7 Gadgets
I use Sushi's DriveInfo and "Wired Network Meter" on top of that CPU meter you linked above. I try to keep the gadgets to a minimum
- Pea0n
Don't run gadgets whats the point all the gadget sidebar does is use up resources for nothing essential really.
i thought that way in vista, but win7 seems to handle them differently, some are useful and if you have a high spec pc then most of the time you have 90% resources available
Very useful on my 2nd screen and less than 1% cpu usage.
You can download my gadgets here and unrar them to the "Location" folder which I have included.
Rainmeter is more useful than gadgets, far more flexible and it's just HTML so they'll match if you fiddle with them.
But Win+D minimises it, which is rather annoying.
Edit - you have some random pics on there MRK! :p
I cant figure out how to install them either - any help?
Drag all the Gadget folders into the Location shortcut folder which mrk included
Right Click Desktop > Gadgets
All should show up there, Make sure your checking all the pages, Then double click whatever Gadgets you want to use to get it to appear on your desktop
