Liked Strata theme for Firefox? Now there's Twenty Ten!
  • Thread starter Thread starter mrk
  • Start date Start date
Best FF theme by far. Loving it, just need to have a look through the Neowin thread and get some Stylish adjustments on
Awful. You've dedicated half your screen to tabs n bars. It would be nice also if the refresh & Home buttons are next to each other and a stop button too.
You don't need individual stop/reload buttons, as they are never used at the same time - you can have a dedicated stop/reload button if you so wish, just customise the bar and put the button where you want.
Huh? I don't have it, I just use the History button menu follow through which has a list of closed tabs that I can restore. Or press CTRL+SHIFT+T or just right click the page and undo close tab.
Just curious mate.
If you disable personal menu, the file/exit/options bar comes up again. Is there a way to hide that bar without using personal?
I've tried it but TwentyTen looks more solid and "complete". The latest update also makes the file button menus much better.
You can use Hide Menubar to hide menubar.
And they can go next to each other along side the home button?
I'm always using the stop button - when on my netbook if I don't want to wait for images to load, and that reload button is just as handy. I just hate how everything is all over the place in both Firefox & IE8. Both aren't as customisable as I'd like (call me fussy etc..)
Sod it, I'm going back to IE6! :)
Lol, fail.
You know you can also click ESC for "stop" ?
Doesn't matter, I'm not fannying around in the dark with my right hand trying to hit the Escape button. You'll be laughing at me for not using a keyboard with 3 million shortcuts next, tut.
So I just downloaded the latest Firefox, the replace the one I got..oh the other day and mucked about with it for 5 minutes. I got my Home/reload/stop buttons together, but there's still too much space devoted to all the bars/tabs etc. Even the option to make the icons smaller doesn't make that much of a difference. Why can't the Menu bar & Navigation toolbar be on the on the same toolbar? Who needs a search box that long?
A customised Firefox uses a few pixels less screen space and makes more use of space than IE any day, on top of that it's way more logical, clearly your "5 minutes" was just meh.
As for fumbling around to press ESC, I don't know what planet your keyboard is from but ESC is the easiest key to press and/or find out of any key on any keyboard.
Planet Steelseries?
I'm not saying it (Firefox) isn't less cluttered, just wish it was more so
Is it possiable to remove that drop shadow from the drop down bookmarks bar?
