Sorry I can't make much from that benchmark above as I normally go by average read and average write < yes I'm a noob.
So what are those figures?
The First row is the speed it gets on big files, so things like big game level loads and moving video files around.
The 4K row shows performance when dealing with small files, in a random pattern, this affects how responsive the system feels, things like windows boots and opening folders full of thumbnails.
The 4k64Thread is a test of how good the controller is at queuing requests, by opening 64 threads of 4k operations at once. Good controllers like the Intel and Sandforce can reorder the requests efficiently to be faster than the single threaded 4k operation.
Access time is the main reason SSD's are so much beter than HDD's at the 4k tests, a tpyical hard drive access time is 13ms, many times slower.
Also I don't get what you mean about them shifting old stock but that they are about to stock these? Are these new or old stock then? Confused is I. Sorry. Also, which Kingston are you refering to that is £30 more?
I meant that nobody would want to buy OCUK's other cheapish (<£150) drives (like the corsair x32, reactor, nova) if they were stocking the Solid2's at <£120 so they are probably trying to sell as many of their old stock as they can first.
the Solid 2's are new drives, announced in January and only just becoming available.
The Kingston that's £30 more is this one
http://www.overclockers.co.uk/showproduct.php?prodid=HD-007-KS&groupid=701&catid=14&subcat=910
Confusingly Kingston do both a V+ and V- series, and this is the revision2 of the V+ series using a Toshiba controller.
[ZiiP said:
carrot]
That second one goes along with the OCZ Spec page which now says the same as the product page. So would that be a good boot drive?? Or is it worth stumping up the extra £30 for the Kingston??
The Solid2 would be a good boot drive. It's difficult to tell exact performance for the kingston, as most AS-SSD benchmarks i've seen are for the 128GB drive, which obviously has better berformance.
From what i can tell, the Solid2 64GB has better 4k performance, but is slower in sequential writes than the Kingston, and for £30 less is definitely the better buy.
