- 31 May 2006
- West London
The V3 is a good block for the money - ideal backup block or for resale - ZCTLOPDFE is the bottom line
The current WU is due to complete in about 4 hours so I'll let it finish that and then faff about with it.so are you using the block without a backplate or
have you added some plastic washers behind the board to give more clearance or
have you 'trimed' the excess from the components.
Backplates can make a real differance (air and water)
and 11c is way to much on water at load.
sounds like uneven pressure or an air bubble.
If you have the thumb nuts at the front you could try adjusting them while watching the temps.
my guess is one is overtighten.
when you first setup a loop it's very easy to overtighen one side more that the others.
One reason the swiftech mounting hardware is so good - is it stops this happening
The v3 doesn't really get airlocks but still worth giveing it a shake![]()
this brings the temps right down so I can drop the fans down to the lowest setting on the fan controller. This will save me from becoming deaf in one ear
Running Prime on all eight cores gives me a max temp of 72 degrees with the fans on low.
Dam that's a high PPD
Stan what rad are you using? I get a max temp of around 72C when folding on an A3 and around a max of 75C under IBT/LinX with 1.375vcore @ 4.2Ghz. (With a HK 3.0 and a PA120.3)
