Hi guys.
My car is a 1999 VW Golf MK4 GTI, 1.8 20v turbo. AGU engine so ko3 turbo, engine wise it's mostly standard bar an APR stage one remap, platinum NGK plugs and a stealth subtle backbox.
Anyways, not long had a service, oil, air filter, coolant, new plugs etc.. car seems a lot more pokey when it comes on boost, feels much torquier. Lately with the damp weather, if I've been pressing on, it's been spinning up a bit in third gear with the sudden power increase! It has been accelerating well in all seriousness. But, today in 5th I overtook someone but put my foot down to get past fairly quickly without changing down and the revs flew up till I quickly let off the throttle. Now in third, fourth and fifth it does the same if it comes on boost fairly hard (I had to try, to make sure and of course quickly let off as soon as revs increased).
Long and short is definite clutch slip, so it's gonna need changing. Now I am not a mechanic, it would without a doubt be going to a garage to be fixed, but I'm after an idea of cost from people who may have had their clutch changed on such a car?
Also interested in what exactly is involved, i.e. a brief rundown of parts that'd need swapping. I'm assuming the Golfs use a dual mass flywheel (whatever it does technically I've no idea) - would this need replacement?
Does gearbox oil need draining etc with a clutch swap? And also will the clutch and brake fluid need draining? I wanted to get it all flushed soon anyway so may do this at the same time if neccessary?
Any recommendations of worthy garages within Stoke-on-Trent if anyones local? I was considering giving PSI tuning a call... I have my usual mechanic to ask too. Suppose I could always ask the local stealers too?
Thank you for any guideance, just wanna prepare my wallet for it, timing is terrible
TAX, MOT due, just booked a holiday, then a borked clutch lol.
Cheers guys.
Dave
Cheers guys.
Dave
