They look great mind you.
but barrys want stuff like imprezas and M3s because theyre gangsta. rx8s are pretty inofensive. it should be pretty barry-safe
I don't know. I get the feeling that if you're buying a 'performance' car on a budget like that then fuel costs (or maintainence) probably aren't irrelevant to you - I'd have thought it'd be something that every buyer in that kind of range might be thinking about. Obviously if someone is buying a 10-15 year old performance car then it could be classed as a 'toy' but a more recent one.....
A car I very much like the look of, but due to the thirst, I'm not sure I could justify it. Mpg wise is probably similar to an M5 (17-23), though I suspect the m5 could probably get more than the rx8 on a long run.
£40 per spark plug
Well well, another RX8 post...
Servicing - Cheap
Fuel consumption - Terrible, currently averaging 16MPG around London and 21MPG on a motorway run.
Oil consumption - 1L every 2000 miles
Performance - Not bad but should be better for the running costs
Back to Norfolk - 24-28
X2
Isn't it?
How the..... do you manage that! lol best I have ever had is just under 300 from a tank, 230 miles motorway and 60 miles or so of country lanes at sensible speeds (mostly) 23-24MPG. 28MPG almost sounds good! As for the alloys, mine are ony slightly gone around the centre caps but nothing major.
