BC2 BETA... Your thoughts and SCREENSHOTS of it
I was shocked to see my kd ratio at 1.25 don't get that as I cant even recall any game I've played when I have been less than 8-2 ratio.
My Stats
Kills 292
Deaths 307
KDR 0.95
Is that any good.
Just looked at my dog tags. And it says I have not taken any. I should have about 6 or 7. As they show at the end of rounds.
My Stats
Kills 292
Deaths 307
KDR 0.95
Is that any good.
They'll come back. I have 25 or so and sometimes they disappear. As do my unlocks. I just reload the game with crossed fingers.
And anything <1 isn't really good - go and kill 20 more people :D
I discovered a "crouch toggle fix" a couple of nights ago so if ur fed up of holding down CTRL (or whatever u have assigned) try this:
hold crouch -> hit "type to team" or "type to all" button -> release crouch -> type something (or dont) -> hit enter = u are now crouched until the next time u hit the crouch key.
Something similar from BF2 where if u had to run a long distance u could press W -> type and leave ur guy running without needing to touch the keyboard.
IMO it should give you dog tags for shooting people, it's harder than knifing them.
I think you should be able to pickup dogtags from any person you killed if you get to their body before it disappears. Also the taking of dogtags should prevent the player being revived.
They aren't really a gameplay mechanic, they're just there to add an extra 'fun' element.
I also don't think anything that directly or indirectly nerfs medics is a good thing either tbh.
