oooooh you can see the ZR24w on here now: http://www.hp.com/united-states/campaigns/z-workstations/ (click on 'Performance Monitors')
My HP contacts say it'll likely be mid march before it turns up widespread availability in the UK, though some places might have limited stock before then. That said, it's a high performance screen designed to be paired with the Z series workstations, do not expect it to be cheap...
But from what i've seen it doesn't support the same array of inputs as their flagship models do so I would expect it to be a bit cheaper?
Suggested price from HP is $425.
Few places have this slated for April, so don't hold your breath
Where did you read this? I cant wait till April I want one now!Where did you read this? I cant wait till April I want one now!
lolI meant March sorry, not sure why I typed April :S. Anyway, most say end of Feb/March time, a couple of supposed "inside" sources quoted on the HardOCP forums, although take that with a pinch of salt.
i think thats the same with most forum "inside sources"loli think thats the same with most forum "inside sources"
