Caporegime
- 12 Mar 2009
Hi, i currently work for Game stores Ltd. I can say that you cannot sell on the majority of PC games due to the authentication key which is overwritten when the game is installed. Some games will allow for reinstillation to the same computer up to three times but that is dependant on each game.
to sum up you cannot sell on a PC game anymore as the authentication code gets deleted off of the disk making it unusable after first installation.
Also, as a side note, the place where you get your games is unlikely to take your PC games back once unsealed unless the game has a fault.
hope this helps.
LOL! If you tell all your customers that then you should be disciplined for misinformation.
