- 19 Oct 2002
- Torbay, Devon, UK
4890s xfire these are worse than the 10.1 hotfix.
Hmm Think I'll roll back to 10.2s,
These 10.3s have caused crashes in NFS Shift and BC2 Beta so far![]()
Hyperst, afterburner is not wrong! Trust me on this.
You need to read my thread about that problem >> http://forums.overclockers.co.uk/showthread.php?t=18116532
Hmm, Looks like you already have done![]()
it sits at.iv done the option above and it now correctly shows the 2nd card as being at 0mhz for cpu and ram, well done for finding that info mate![]()
sure, go into the msi afterburner folder in program files, i just right clicked the desktop shortcut and clicked on open file location, theres a file called msiafterburner.cfg, open that file in notepad and change the AccessibilityCheckingPeriod option from 0 to 1
click save and exit, then restart the afterburner program.
sorry about the colour change, dont know how to change it yet
