I'd like to see you aim it straight![]()
It has a spinning motion that keeps it aimed flying head-on towards you, so don’t forget to get out of the way.
vacuum and gentle acceleration \o/
In school you always heard daft stories about people getting killed by dropped sandwiches etc![]()
At what speed would a banana skin begin to break up and the contents "fly" out?
I saw a video of a tallow candle being shot through a 4 inch plan of wood. The plank did not come out of the exchange well.
Moral of the story: it doesn't matter how soft it is, if you give it enough speed, you could kill someone with it.
So potentially the answer to the thread is yes, a banana can kill you, but only when you're the wrong side of the outer atmosphere?
I will sleep better at night now.![]()
Yes but you have to give it enough velocity. I seriously doubt a banana would be able to withstand the force required to get it to a velocity sufficient enough to kill someone.
I bet you could reach some high speeds with an air cannon and salvo. Weather you could reach speeds high enough to cause damage is anyones guess.
edit - salvo is not the word I'm looking for, what's the thing called where you wrap a projectile usually in foam to get it to fir a barrel. Which then separates and falls of once out of the barrel.
Yes but once it hits the air will the banana withstand the air resistance (if it survived the blast in the first place)!!!
I'd fire a banana into it if I could!
The large hadron collider might be the answer.
Anyone got a contact at CERN?
you saying he's got a fine assI fired a potato into his ass - it was fine!![]()
you saying he's got a fine ass![]()
If you threw one out the ISS it would easily destroy a satellite if it hit it
Might possibly do severe damage to the space shuttle too especially if it was orbiting in the opposite direction..
Death by banana sounds like a nice way to go.![]()
