[ folding ] Ukraine will pass us in the next 24 hours.
17 May 2006
Manchester, UK
Our recent drop in production has brought Ukraine's average back above ours. For a while we were easily outproducing them and overtook them. Now the boot is on the other (borscht eating, eastern european, gas producing) foot.
There are mumblings of increased ppd (Biffa, walls, BigStan) so this thread is for people to say whether their production is going up or down and when.
Positive momentum needed!
My server is being a little slow to set up - still waiting on an RMA'd HDD to finish the RAID array. I still also need to cable up the attic since that will be its new home. I am also a little concerned about the noise from both the GTX260s. I am worried it will be loud enough to bother my parents [whos room the server will be above!].
So in summary, my current 11-13K PPD is all I got for the time being. If everything goes according to plan I will be pushing out an extra 15K+.
I suppose this is also the time to mention a possible partnership with Stelly. He has a number of GPUs he wants to bring over to my username. However, I have not heard from him concerning when he plans to do this, if he still wants to go ahead.
Alright dude...
I will be joining soon, just looking at getting the OS installed on the computer and getting everything setup, been busy the last few days :(
Stelly
I've been folding on and off for the past couple of weeks or so (alongside SETI, which still has quite a few WUs left to do). Am running one GPU client and one SMP2 client, which on this rig is good for 12-14k PPD.
Alright dude...
Stelly
OK cool. I figured you had to do some fettling still. I will look out for a nice boost in my *cough* our PPD soon :D
Good to hear :D
Erm i should be back to folding around thursday i hope, i have a gigabyte UD3 the new model i will order the case next week so it will sit on my desk all naked an new :eek: :D and will also be picking up a old GTX seeing as i knackered my old one, will hopefully be back to my old output then, i cant wait to get it built i am so bored its unbeliveble dont think i'll be destroying anything again in the long run :)
Im still awaiting my rma replacement for my 9800gx2 which should help up my ppd by around 10k.
once it arrives i can then set about redoing my system with 2 8800gt under water as well as 2 9800gx2 and finally use the new mobo i bought months ago and get a stable oc of about 3.8Ghz on my phenom ii 940.
Just did the hairy switchover mobo/cpu/ram on my main machine.
Managed to:
drain loop
remove block
remove GTX260 (without disconnecting loop)
Remove old kit from mobo tray
put new x58/i920/DDR3 kit on mobo
put new heatkiller block on cpu
replace mobo tray
plug all back in..
Refill loop
Leaktest... *phew*
Boot up...
nothing...
CF on mobo LED.. arrgh.. says its ram
remove all but one stick
replace stick by stick
nothing... CF...
move single stick from yellow slot to green slot
BOOTUP!
Shutdown, replace remaining sticks in other two green slots
BOOTUP! ... bios.. check.. save... reboot... Windows!
Drivers.. drivers...drivers... Zzzzzzzzz... drivers...
Should be done soon.. then an extra bit of boost.. and try some overclocking
Doing what I can, I've had a personal record day - even managed to claim my position back off Vertica! Having said that I don't expect to have it back for long :(
Ok update 8800 died, down to 1 GPU, BUT I have just sent back my GPU to BFG so I hope a week turn around (hopfuly) I will keep you all abreast :)
Stelly
