Hang on.....I'll just pop a 5970 in my basket...thats 550 quid.....damn I can save 70 buying a Phenon II 965....
Doh If I go for a http://www.overclockers.co.uk/showproduct.php?prodid=GX-128-PC&groupid=701&catid=56&subcat=1577 @ £499 then the i7 will only be 20 quid more....
Man this buying PC hardware is so tricky![]()
Gotta love all this 20-50quid diff of yours after you take most expensive mobo for AMD and most crappy one for i7.
How about:
i7 920 - 220
mobo - 150
ram - 120
TOTAL= 490
VS
555BE - 75
mobo - 60
RAM - 80
TOTAL =205
490 - 205 = 285 , thats 5850f worth of difference ...
Now you gonna come with OMG OMG but thread is about 965 not 555, I could take i5 for lesss toooo.
i5 750 - 160
mobo - 75
RAM - 80
325, still 120 difference and you're loosing the edge that i7 gives you with extra threads.
I still get more GPU power and I still win.
You loose get over it
.And lower res isn't going to make the AMD go any slower, it can only get more FPS at lower res, not less.
If it's completely playable at max details with 2560x1600 that only proves my point that you don't need i7 for gaming.
And who gives a damn if you get 230fps instead of 200fps ...
"Oh you should buy best you can afford, so you can e-peen around like me with few fps extra in benchmarks".
And all this future-proof BS.
If you do a search on MM for i7 you'll see at least 10selling each week...
I wonder why half of the uber i7 gaming buyers sell their stuff withing 2-12months.
I guess they just realised that they're getting ripped off...
You're just upset that games are just as playable on my 200quid setup as on your 500+ setup.
No matter how you put it, you can't change the fact that games are GPU limited and will play just fine with any CPU above 3.2-3.4ghz (even 3core for 40quid will do) as long as you slap 5770x2, 4890x2, 5850, 5870 or similar in there depending on the res you play on.
Encoding / servers etc - i7 yes please.
Gaming - AMD.
E-Peen Max - dual CPUs under phase or 975extreme with LN or high end water.
I'd rather spend the extra 50-100-200-300quid difference on watercooling/ssd/gpu.
Fine, if you want to throw out 2-3grand then can just as well take it all, but only if you can afford all of it.
