So what have you lot got against golfs?!
I wonder why Fox doesnt reply to your posts anymore. :p EDIT - Turns out he does!
Wind noise etc is part of the DESIGN, not build quality. Whether you think they are 'quality' materials or not is PERCEPTION. Marketeers and journalists refer to it as build quality because thats what the common public believe what the definition of quality is.
Now if you came along and said that there's wind noise due to panel gaps etc, that occur in some of the cars and not others. THAT is a failure in build quality.
Love it. ;)
If you were wondering, then you care a lot more than I do!
Build quality covers different areas. There is no generally recognised definition of build quality. Most that do exist are sufficiently vague that they can incorporate several factors, such as the quality and extent of the materials used and the quality of the workmanship in installing said materials, as well as the reliability of the product. You have your definition and I have mine, neither of us can reasonably fabricate a very specific definition to fit in with our own argument. However, to say that the level of road noise in a car bears no relation to some aspect of its build quality, is probably the most bizarre thing I've ever read on this sub-forum.
Design and build quality are inherently intertwined. They are not entirely separate factors. Good design allows for good build quality, good build quality follows good design.
One definition I found that I agree with:
"Build quality is not an easily or objectively defined concept but it refers, generally speaking, to how well designed and constructed the product actually is from a subjective point of view. This includes factors such as reliability, sturdiness, fit and finish (if the product appears smoothly made and polished or is rough and ready), quality of materials and so on."
Taken from here. Granted, not the ultimate authority on the definition of build quality, but as sensible a definition as any other I found.
If the quality of the materials is high, then it can be said, in my view, that this fulfilment of the design criteria contributes towards a higher level of build quality.
[TW]Fox;16073853 said:
How can they be? Surely road noise depends on a cars design breif not its build quality?
No, the road noise depends on a car's fulfilment or otherwise of the design brief, not the design brief itself. Without the quality and quantity of sound deadening materials required to reduce road noise, a car cannot fill its design brief if part of that brief was for the road noise to be low. I can brief a brilliant car but build it terribly, not securing the deadening properly, not using enough dampening, not using the right quality of materials.
By your ethos, I could write a design brief that the car must have very low cabin noise, thereby automatically defining the car as having a low level of cabin noise, even if the execution of the brief was poor and it ended up sounding like a 747 on takeoff.
@Fox - You ruined the panache of my opening statement! :P
I wouldn't worry about that ;).
cymatty, I'm not sure that you brought anything insightful to the discussion there. My argument is that build quality would determine the extent to which those noisier tyres increased road noise.
Well done for totally ignoring my point. Good luck with your idea that a Peugeot 308 is better built than a Porsche Cayman as it has less road noise.
I would try to defend my point, but I'd only really be repeating what Fox has said, and I just dont have the energy
But low road noise probably wasn't part of the Cayman's design brief :confused:.
I did not ignore your point, I confronted it and exposed it as wrong. You seem to be failing to understand the difference between low road noise being the solitary factor in build quality, as opposed to low road noise being one possible factor in defining build quality.
So you say the Golf has lower road noise than the focus (open to debate) - what if the Focus' design brief was handling over road noise? Does that still mean the Golf is a higher quality product?
My personal belief is that the quality of the 2 cars is pretty much comparible, just expressed in different areas - so quality isnt a good reason to pick one over the other. Most Golf buyers do so because of percieved quality because the door goes thunk
Exactly. Therefore to say that road noise is linked to quality is daft. Some of the quietest cars I've been in had a Citroen badge on the front. The door handle then fell off on the way out. Some of the noisiest cars I've been in had a BMW badge on the front and had a very well built cabin.
Lets open that up to the floor - does anyone think Robbie G has 'exposed my point as wrong'?
Whereas you seem to be... failing.
The new Ka I was in today was incredibly well built - I didnt notice any road noise at all!! *
Didnt get above 15mph due to traffic
Stuff about 'no definition for build quality.'
I know my career in the Motor Industry isn't extensive, but working in Product Development I know to myself that I'm correct, my statement is DEFINITE, and cannot be proven otherwise. It's the standard the whole industry uses, and as an engineering definition it is absolute. Build Quality, and Percieved Quality. You sir, are talking about the latter. I rarely say something so definitive as this. As I inferred before. you share the same 'view' of quality as the common consumer, you can't be blamed for that, the majority of people think of quality as what you say. But what you can be blamed for is your antagonistic approach whenever someone opposes you.
You still can't understand the concept of low road noise being one of many indicators of build quality, as opposed to it being the entire defining factor as to the whole car's build quality. Accordingly I give up, as it's like drawing blood from a stone.
How can you expose an opinion as "wrong"?
Quite easily. For example, "my opinion is that the earth is flat". Even you should be able to debunk that one, champ.
I know my career in the Motor Industry isn't extensive, but working in Product Development I know to myself that I'm correct, my statement is DEFINITE, and cannot be proven otherwise. It's the standard the whole industry uses, and as an engineering definition it is absolute. Build Quality, and Percieved Quality. You sir, are talking about the latter. I rarely say something so definitive as this. As I inferred before you share the same 'view' of quality as the common consumer, you can't be blamed for that. But what you can be blamed for is your antagonistic approach whenever someone opposes you.
My father is a FICE, so you'll forgive me if his opinions carry more weight to me than some guy that worked in product development for a bit :D.
Kappa is absolutely 100% right. 'Perceived quality' can be engineered in, actual quality is much harder to acheive.
Making the door go 'thud' is far, far easier than making the car as effortlessly reliable as a pre-accelerator-pedal Toyota, for example. Yet the latter is not seen as having good build quality..
Therefore an opinion can't be wrong.
Well exactly, likewise saying that his opinion that the earth is flat (as a stupid example to make a point) is daft because it's something that can be, and has been, proven definitely wrong
No problem, if an open day was possible I'd invite you for a coffee and to meet one of 2,000+ Automotive Engineers over at Dunton, Essex. ;) Surely you can go down the road to Gaydon and ask?
Maybe he needs to understand the meaning of the word opinon.
http://www.google.co.uk/search?hl=e...&oi=glossary_definition&ct=title&ved=0CAgQkAE
Oh my dear lord.
a personal belief or judgment that is not founded on proof or certainty
An opinion that is not founded on proof or certainty can by its very definition be debunked by proof and certainty.
Of which you are clearly not one.
Exactly, it's an opinion that has been proved wrong, so what the hell are you talking about when you say
Oh my dear lord.
Pretty much sums up my feelings on you and your argument.
When an opinion states purported "facts," it is the fact that can be incorrect. However, your opinion based on erroneous facts is still just an opinion.
