I tried 8 x 425 and errored in prime. We'll see how i get on when 2x2gb arrive, hopefully tomorrow. C64, i suppose you are right but when i spend £50 on a cpu cooler i expect it to be able to overclock at least 200mhz higher, being that load temps are down 25c from before on a scythe heatsink
I would rather have 3.2 and lower temps than 3. whatever and crazy temps 3.2 should be enough for most things. **ORIGINAL MESSAGE** pretty shocked at 70c under that true and noctua + silverstone fortress ? thought it would be much better than that or is it not a q6600 G0 ? **ORIGINAL MESSAGE**
No worries nothing bad meant in what I had said, it's because I have just bought the same case as you and was a little surprised/concerned temps weren't lower is all.I expected 60-65c maximum which sounds about right reading the above.
