I tried 8 x 425 and errored in prime. We'll see how i get on when 2x2gb arrive, hopefully tomorrow. C64, i suppose you are right but when i spend £50 on a cpu cooler i expect it to be able to overclock at least 200mhz higher, being that load temps are down 25c from before on a scythe heatsink
) you will have the possibility of using a lower multi and higher FSB to get there.I would rather have 3.2 and lower temps than 3. whatever and crazy temps 3.2 should be enough for most things. **ORIGINAL MESSAGE** pretty shocked at 70c under that true and noctua + silverstone fortress ? thought it would be much better than that or is it not a q6600 G0 ? **ORIGINAL MESSAGE**
but the original came into my inbox
And tbh I didn't think 70c topping out in Prime was all that bad at 3.6 running 1.43v through the CPU. That was recorded with my tjmax at 100c too, so the actual temp was probably some 5-10c lower.No worries nothing bad meant in what I had said, it's because I have just bought the same case as you and was a little surprised/concerned temps weren't lower is all.I expected 60-65c maximum which sounds about right reading the above.
